Post by intim2023 on Dec 25, 2022 7:21:57 GMT -6
i have the linhai aeolus 300 (2007) its pretty awesome good luck man. currently have mine tore apart about to replace the valves and head gasket. grab yourself a new starter solenoid with copper terminals
Post by intim2023 on Dec 25, 2022 7:15:04 GMT -6
my battery doesn't seem to be charging either so someone said it's the R/R whatever that is im doing more research now.
Post by intim2023 on Dec 25, 2022 7:12:01 GMT -6
new owner of a jonway yy250t. it's missing all the body panels on the front save the gauge cluster and the headlight itself which isnt installed yet. runs great has the 244cc vertical style head engine. ive had it up to 60mph it rides great.
Post by intim2023 on Dec 25, 2022 7:09:57 GMT -6
that's exactly what it is. the two wires that are going to your brake lever well you can connect them together and then see if the starter button works. if it does then that's your issue. remember to put the wires back the way they are otherwise your brake light will stay stuck on.
