Post by kt on Jul 2, 2011 20:41:09 GMT -6
Ok thank you. I am going to do whatever and get it fixed. I am just worried. I have heard some pretty bad stories about Chinese scooters falling apart. Have you found this to be a common thing with these scooters?
Post by kt on Jul 2, 2011 18:20:34 GMT -6
ok that didnt work ... I went and purchased new fuses and replaced the old ones. And then, ... the scooter wouldn't start? I put the old ones back in and the scooter would still not start. So, I had it towed to a shop. Hopefully it isn't something that will cost too much.
Post by kt on Jul 2, 2011 8:04:57 GMT -6
Thank you. I am going to go get new fuses now and see if that makes a difference. I will get back on and let you know. If this isn't it, i am a bit nervous doing much more .
Post by kt on Jul 2, 2011 5:33:16 GMT -6
YES that is exactly what my fuses look like! I have pushed each of them in tightly so replacing them is probably needed. Next question, where can I go to get fuses? sorry if that is a silly question, just never have had to do this before.
Post by kt on Jul 1, 2011 21:32:13 GMT -6
With regards to the fuses, i found one container near the battery that contained 4 fuses total. They are number 10's? I pulled them out and looked at them and they looked ok. I also pulled them out one at a time and started bike up.
Post by kt on Jul 1, 2011 21:29:06 GMT -6
Tail lights are working ... I don't need to flip a switch for them. The high beam light works when I push down on light switch but headlight bright will not stay on. Blinkers work. But low beams and dashboard are not coming on at all? I am so frustrated.
Post by kt on Jul 1, 2011 13:06:46 GMT -6
I have a JMstar Bali 250cc does that answer your question?
Post by kt on Jun 29, 2011 22:09:10 GMT -6
Help... My lights on my scooter are now not working? My dashboard and my lights (that are normally on when I start my scooter) are not working. Anyone have an suggestions? I checked my fuses and they are good. Past that I am a girl and have no clue..... HELP
