Fatten
by: wolly48 - Oct 27, 2011 14:55:16 GMT -6
Post by wolly48 on Oct 27, 2011 14:55:16 GMT -6
Thanks for the post. I really appreciate it. I will certainly change the anti-freeze.
Fatten
by: wolly48 - Oct 27, 2011 5:53:22 GMT -6
Post by wolly48 on Oct 27, 2011 5:53:22 GMT -6
Thanks for clearing that up. I did get a good deal of the scooter, but still put hours into getting it to run. Started with kick stand sensor issue. Fuel pumps problem. Carb problem. Light diode issue. Battery shot. And a few other small items. I now have 17 miles on it!!!!
Fatten
by: wolly48 - Oct 20, 2011 19:26:53 GMT -6
Post by wolly48 on Oct 20, 2011 19:26:53 GMT -6
OK, so how do you put the picture into this block?
Fatten
by: wolly48 - Oct 20, 2011 16:14:32 GMT -6
Post by wolly48 on Oct 20, 2011 16:14:32 GMT -6
I just purchased a Helix clone 250 scooter. On the instument panel is the lite work "fatten". They must want you to see it, as it is on both sides. What does it mean? Thanks in advance,
Post by wolly48 on Sept 14, 2011 13:36:52 GMT -6
Thank you,
The diode arrived today. I put it in the scooter. Lights stayed off until engine was started and charging system is working. Problem Solved.
Thanks for the Forum!
Wolly 48
Post by wolly48 on Sept 12, 2011 5:30:05 GMT -6
Thanks guys for all the help. The diode that is in both post do not look like mine. I searched many sites on the internet and finally found it @ Chinese Scooter Parts Online. ( under DIODE section)
Post by wolly48 on Sept 9, 2011 19:00:04 GMT -6
New 250 chaunl scooter working on getting bugs out of scooter. Let it set over weekend. When returned on Monday battery was dead. Hooked up charger, as soon as I did headlights and dashlights came on with engine off and no key in ignition. Having hard time with little info on this issue. HELP!
