Post by prodicalram on Aug 4, 2022 19:28:11 GMT -6
Thank you I will try that. I ordered a jet kick just waiting for the weekend
Post by prodicalram on Aug 4, 2022 12:22:44 GMT -6
I am sorry to hear about the original Creator. Hopefully I can get some to help on my thread.
Post by prodicalram on Aug 2, 2022 8:48:51 GMT -6
Hi all I have a 2021 Dongfang Falcon 200. I recently replaced the tamper proof carb with an adjustable one. It has a 161qmk engine and the carb is a pd24j. The replacement carb has a 103 main and 35 idle. Do it is starving for fuel. I just need to know how much to up jet to. I opened the stock carb and the only jet labeled was the main and it is a 90 but that doesn't seam right. It still has the stock air box and exhaust. Any help would be greatly appreciated.
Post by prodicalram on Jul 18, 2012 15:08:32 GMT -6
When you say security do you mean the alarm? Not worried about the alarm but I do see your point on being able to hop on and go when I. Am not at home
Post by prodicalram on Jul 18, 2012 12:31:22 GMT -6
Update. OK I figure out the brake light it turned out to be the fuse. Now the turn signals turned out to be the ignition. I found this out the hard way when it went poof. the engine wouldn't shut off with the key.( had to remove spark plug wire to kill her and disconnected the batt for good measure.) I took the key out of the ignition and the left side of the key was scorched. I have to wait till next week to order the lock set to fix her though.
Post by prodicalram on Jul 17, 2012 12:00:16 GMT -6
Update, I cleaned my Grounds and checked the the connection for the brake light assembly , which looked fine. So I inspected the flasher relay. The relay is thrashed it is missing it's back cover and is all corroded. My question is can that affect the brake light? I know they share at least part of the same circuit( according to the schematic) Ram
Post by prodicalram on Jul 16, 2012 9:58:50 GMT -6
Thanks for all the info John and rich I really do appreciate it. I haven't had a chance to dig into her again yet. I'm gonna try to get to her this afternoon and I will update
Post by prodicalram on Jul 15, 2012 15:56:27 GMT -6
Hi All, This is my first post here and I have a question. First off I would like to say I have gotten a lot of help just from reading the boards. I have a 2007 150cc retro Road Runner I scooter with 1p57qmj engine. Her name is Geraldine lol. I bought her used from cl and even after the minor work I put into her she was still a good deal ($350). I had to re-jet her ( she had a 103 and would only go 35) so I put a 110 in her, which fixed that. I adjust the valves and cleaned out the carb. I put on a high flow filter cause my air box was thrashed and removed the egr system. Ok now for the current problem. For awhile now my turn signals and brake light have only been working intermittently. Now they have gone out completely(headlight and horn still work). I traced it to what I thought was the issue( partially melted wire behind the plug under the plastic over the muffler) I fixed that and still no lights. I would greatly appreciate in help thanks. Ram
