Post by remi2k7 on May 12, 2013 10:14:24 GMT -6
Sorry for the real late reply I have been real busy at work. but once again ty for all the replies.
but so far I tried everything except adding fuel to the intake manifold to try to start it up, so i ended up just buying another complete engine since it was pretty cheap like $200 and cause well this is my only transportation to work. However I am going to still try to get it to run and will post it once it does.
Post by remi2k7 on May 6, 2013 21:35:30 GMT -6
First of thank you guys for taking your time to help me ![:)](//storage.proboards.com/3059616/images/ELWck45kIaBpPYtpvDIj.gif) So this is what happened, I was driving back from work and stopped at a stop light and all of a sudden my engine stopped. When i try to start it makes the same sound as this video I forgot to mention i put a 50mm bbk it was running for like 2 weeks So far i have check for spark, changed; fuel and vac lines,filter, carb, changed spark plug and coil, did valve adjustments, took out the bbk and put the original one back on (i don't have compression tester) the bbk seem fine though . The only thing i can think of, is that i burned the engine q.q cause when i took out the bbk it smelled like bad burned oil so my question is what other things can cause a scooter to not start? Again thank your time
