help
by: 2006laser - May 18, 2014 0:05:01 GMT -6
via mobile
Post by 2006laser on May 18, 2014 0:05:01 GMT -6
2006 tgb Laser will idle when its cold and only run with throttle when its warm....any suggestions?
help
by: kz1000st - May 18, 2014 1:22:17 GMT -6
Post by kz1000st on May 18, 2014 1:22:17 GMT -6
Check the valve clearances or run Seafoam in the gas tank. It sounds like you're losing either compression or running a lean mixture after the choke signs off.
help
by: 2006laser - May 18, 2014 1:32:06 GMT -6
via mobile
Post by 2006laser on May 18, 2014 1:32:06 GMT -6
Thanks ill try the sea foam first...plus its available....do you have to take the valve cover off to get to the valves....I had a matrix that had a slot so you didn't have to fully remove the cover....can you tell me what kind of laser I have....its 150 CC but I don't believe it is an r9....thanks for responding
help
by: Bashan - May 18, 2014 6:31:04 GMT -6
Post by Bashan on May 18, 2014 6:31:04 GMT -6
If you post a picture of your scooter it would help to identify it. Yes, the valve cover has to come off to adjust the valves.
