Post by jokerstats on Nov 5, 2015 15:27:07 GMT -6
hello I bought a 2006 lance 150cc scooter from a auction and it's came with nothing from the pole up! No flywheel no stator no magneto no fan and no fan cover! This is my second scooter and really my first attempt to fix one but all videos looks easy the only thing I need to know is what parts to order? And what pole? 6-8-11? I asked a parts dealer and they said they couldn't help? Please someone help with advice!!!!thank you jokerstats
Post by tvnacman on Nov 5, 2015 17:36:40 GMT -6
welcome to the forum We will need some more info. Can you locate the regulator? Is the harness damaged? John
Post by flaco on Nov 8, 2015 16:39:44 GMT -6
11 pole is really only used if you want to run HID or a killer sound system. If your not then go with the stock 6 pole. I have a 62mm a12 cam and it runs great with the stock 6 pole. Of course you need to check the wiring to make sure its in good condition.
Post by Alleyoop on Nov 8, 2015 19:29:49 GMT -6
First thing to know to get the right parts is WHAT MOTOR IS IN THERE. Look on the MOTOR CASE by the SIDESTAND the motor type will be itched into the casing. Like this: Also never put a 6 pole stator always AT THE VEERY LEAST AN 8 pole stator which just about all 150s come with. Some of your 50s come with a 6 pole. So Get back on what type of motor is in there: Alleyoop
Post by tvnacman on Nov 10, 2015 5:59:09 GMT -6
very interesting comment, would that 62mm cam work better with an 8 or 11 coil stator. I have no idea how a cam and stator work together. Please explain? John
