Post by mahnut on Oct 16, 2016 14:36:25 GMT -6
Post by cyborg on Oct 16, 2016 16:36:05 GMT -6
If your running the original carb it's too small and you're running super lean,,,, this makes it run very hot which leads to damage,,,,, pull the plug and check the color,,, probably be white which is not good
Post by mahnut on Oct 16, 2016 17:26:20 GMT -6
ok so i have to adjust the screw to make it more richer. Yes, i did took out the plug and the tip of it appeared to be white. I ran it for maybe 20 minutes at such condition. Could the piston already be damaged? Also what do i do if i get uneven RPM's it goes up and down by 2 bars, and you can actually hear that its not running even. THANSK!
Post by tvnacman on Oct 16, 2016 18:24:29 GMT -6
did you try to contact the vendor?
Post by cyborg on Oct 16, 2016 19:32:39 GMT -6
You need to go up in the main jet ,,,, I personally would go to a bigger carb,,,,
