Post PDI
by: 260orbust - Aug 23, 2010 20:12:09 GMT -6
Post by 260orbust on Aug 23, 2010 20:12:09 GMT -6
I'm really thinking it something with the engine, it just doesn't feel the way it did. After the valve adjustment it was pretty smooth but after a few days all this started happening. And it happened in stages ya know? First I had to get to about 30 m.p.h before it would accelerate, then 45 m.p.h, then 50! Best way I can describe it is the engine runs but feels weak. I figured I didn't have the carb adjusted right or something. Could it be the intake valve has closed up?
Only other thing I can think of is maybe something did get sucked into the carb because I don't know how long the air hose had been off. I'll shoot a video of the CVT operation tomorrow, didn't have time today and I'm at work now.
Post PDI
by: 260orbust - Aug 25, 2010 5:48:41 GMT -6
Post by 260orbust on Aug 25, 2010 5:48:41 GMT -6
Here's some video of the variator and clutch in action let me know if it looks right. Took it up to about 7K but it was hard to see and video at the same time. Forgot one
Post PDI
by: 260orbust - Aug 25, 2010 6:03:43 GMT -6
Post by 260orbust on Aug 25, 2010 6:03:43 GMT -6
Wow! Man this is crazy I'll have a go at it but I definately won't be able to even attempt that till the weekend. In the mean time I'll try and check out the intake side of things.
Post PDI
by: 260orbust - Aug 25, 2010 6:26:30 GMT -6
Post by 260orbust on Aug 25, 2010 6:26:30 GMT -6
Well I thought I tighten them really good because I didn't want to have to do it again for a while but it was my first time so who knows. I still haven't replaced the rest of the stock vac hoses because I didn't really think they were a serious problem. So I think I'll just redo the valves and everything else this weekend. I work evenings and by the time I get home it's dark and I'm too tired anyway. When I wake up I don't have a lot of time to fool with it but since I won't be riding any time soon might as well take the plastic parts off at least.
Post PDI
by: 260orbust - Aug 29, 2010 22:27:37 GMT -6
Post by 260orbust on Aug 29, 2010 22:27:37 GMT -6
OK checked the air intake: Nothing there, fixed the hose connecting to the air box but now the hose won't stay on the carb! Wonderful! Checked the valves: Nothing strange there. Did not pull the clucth yet will do it tomorrow, don't really think that is the problem but we will see. Results of all this??? The Same! I'm about to lose my religion here!!!!! Is it supposed to make a noise when you roll it (engine not running)?
Post PDI
by: 260orbust - Aug 30, 2010 5:18:29 GMT -6
Post by 260orbust on Aug 30, 2010 5:18:29 GMT -6
Not the engine but from the clutch/tranny area. Sort of an intermittant grahhhh... grahhhh sound
Post PDI
by: 260orbust - Aug 30, 2010 6:29:29 GMT -6
Post by 260orbust on Aug 30, 2010 6:29:29 GMT -6
I was fooling around with it and realized the weights would not stay in place. It seems to be working as it should, the belt is going all the way to the top. The noise happened when I shut the engine off and was pushing it a few feet.
Vstar 650 Classic
Post PDI
by: damin69 - Aug 30, 2010 8:34:34 GMT -6
Post by damin69 on Aug 30, 2010 8:34:34 GMT -6
Mine would make this noise every once inawhile found out it was one of the rear brake pads would make this weird grrr chirping sound.
Post PDI
by: 260orbust - May 2, 2011 6:47:18 GMT -6
Post by 260orbust on May 2, 2011 6:47:18 GMT -6
OK Sooooo I finally got off my built in cushion and took a look at that scooter. I had just gave up on fixing that lousy scooter but then months ago I was passing a scooter shop (non chinese brands) and decided to ask them for help. They suggested I check the carb. The carb.... Hmmm... Didn't think of it cause it's only got 3700K on the clock so what could be wrong in there. Well I took a look at the "how to" video on this site and finally took the darn thing off this weekend. As I'm watching the video and noticing the diaphram on mine is different I see that there is a 1/4 inch slit in it. So I took a piece of rubber glove (about the same thickness) and put a thin spread of rubber gasket maker on and TA-DOW! Put it back on and took a test drive and other than some low speed bogging it was fine. Hopped on the freeway and pegged it at 72 on the speedo. Now how did this happen?? Again only 3700 miles so I don't get it. I still have to figure out some way to get an air intake hose on there cause the one that came with it will not stay what so ever. Also, does anybody know if there's a rebuild kit for the Keihin CVK. I just need the diaphram.
Post PDI
by: kz1000st - May 2, 2011 6:52:36 GMT -6
Post by kz1000st on May 2, 2011 6:52:36 GMT -6
