Post by willemjjbotha on May 16, 2017 13:16:38 GMT -6
Hi all, does anyone know if it would be possible to put a 150cc barrel with piston and head onto a 125cc 152QMI engine? The barrel is to thick so it does not fit into the hole in the case were the barrel mounts. Is there any possibility that one can make the hole bigger for the barrel to fit? Also will the conrod length be OK ?
