Dying on me
by: 125scooterbro - Feb 28, 2018 11:20:24 GMT -6
via mobile
Post by 125scooterbro on Feb 28, 2018 11:20:24 GMT -6
Hi guys i try to fix this problem for a while, i have this 125cc chinese scoot wich just starts and bogging down after half a minute and if i give it gas it quits sooner, the scoot have only 10.000km, the compression is good. Here's what i did, put new fuel lines, new coil spark plug, carb, cdi, remove that pair system emission control non sense, petcock, intake manifold and that's bout it. I did this one by one of course to be sure wich part is bad, summer is soon here and i dont know what to do with this thing right now, any help would mean a ton
Post by czmdiver on Mar 1, 2018 7:15:01 GMT -6
Ok welcome 125 What is the make and model of your Scoot?? sounds like she's starving and running out of Fuel. You mention a petcock, do you still have or ever a Fuel pump? The gas cap may be vented, if this vent is not working she will run outa fuel as you describe..
Dying on me
by: 125scooterbro - Mar 1, 2018 12:20:40 GMT -6
via mobile
Post by 125scooterbro on Mar 1, 2018 12:20:40 GMT -6
Ok welcome 125 What is the make and model of your Scoot?? sounds like she's starving and running out of Fuel. You mention a petcock, do you still have or ever a Fuel pump? The gas cap may be vented, if this vent is not working she will run outa fuel as you describe.. Hi, thanks. It has no fuel pump but a petcock as stock, it is a Qingqi 10-H, is similar to a Qingqi 10-D only some different plastic panels and airbox is mounted on the top of the engine, as you say i was thinking about the gas tank venting, i try run it without the gas cap with same results, on top of a gas tank it's a hose next to the fuel sending unit wich go to the petcock, is that the venting?
Dying on me
by: 125scooterbro - Mar 11, 2018 6:02:04 GMT -6
via mobile
Post by 125scooterbro on Mar 11, 2018 6:02:04 GMT -6
Quick update, i am pretty sure my engine is flooded, now i read some articles but there is an expert around who knows wich is the best way to fix this? Many thanks in regards
Post by cyborg on Mar 11, 2018 10:01:05 GMT -6
Put the old carb on and see what happens
Post by scrapiron1205 on Mar 11, 2018 19:38:21 GMT -6
Hi guys i try to fix this problem for a while, i have this 125cc chinese scoot wich just starts and bogging down after half a minute and if i give it gas it quits sooner, the scoot have only 10.000km, the compression is good. Here's what i did, put new fuel lines, new coil spark plug, carb, cdi, remove that pair system emission control non sense, petcock, intake manifold and that's bout it. I did this one by one of course to be sure wich part is bad, summer is soon here and i dont know what to do with this thing right now, any help would mean a ton Well could be a little bit of these things to check out washer ring could b gone off gooseneck a vacuum hose could b loose filter could b stopped up
Dying on me
by: 125scooterbro - Mar 14, 2018 12:55:05 GMT -6
via mobile
Post by 125scooterbro on Mar 14, 2018 12:55:05 GMT -6
Hi guys i try to fix this problem for a while, i have this 125cc chinese scoot wich just starts and bogging down after half a minute and if i give it gas it quits sooner, the scoot have only 10.000km, the compression is good. Here's what i did, put new fuel lines, new coil spark plug, carb, cdi, remove that pair system emission control non sense, petcock, intake manifold and that's bout it. I did this one by one of course to be sure wich part is bad, summer is soon here and i dont know what to do with this thing right now, any help would mean a ton Well could be a little bit of these things to check out washer ring could b gone off gooseneck a vacuum hose could b loose filter could b stopped up Nope. Every hose is new and tight, new fuel filter
Dying on me
by: kz1000st - Mar 14, 2018 17:38:21 GMT -6
Post by kz1000st on Mar 14, 2018 17:38:21 GMT -6
Valves adjusted? A loss of compression might let the vacuum petcock clamp shut.
