Direct bikes DB50QT11, a 49cc with 139QMB engine, won’t rev
by: aaitken - Sept 7, 2020 3:46:54 GMT -6
Post by aaitken on Sept 7, 2020 3:46:54 GMT -6
The problem.
My daughters Direct bikes DB50QT11, a 49cc with 139QMB engine, won’t rev up and has sooty plug.
The moped will start, with difficulty, often using starter fluid. It will then idle until warm, and may occasionally cut out, so needs a throttle tweak to keep alive. But it won’t rev to power. It partially revs up, but not really enough to move the back wheel when on the stand, and can’t propel itself forward even if you stand by it and rev it to the max.
The spark plug looks very sooty when pulled. I can wire brush this off, and it will be sooty again after a few minutes of running at idle.
I am getting I think white (not blue) smoke from the exhaust. It doesn’t smell oily.
Things I have inspected:
The plug is sooty on any inspection. It is an NGK and I have checked the gap, it is about 0.63mm.
Valve clearances. Inlet and exhaust are currently gapped at 0.10mm which I think is about 0.004”.
Compression: I was able to borrow a gauge and when warm I was getting up to 125psi on the starter motor. Only took a few seconds to peak there. I no longer have access to this tool, so won’t easily be able to repeat the measurement.
Sucking on the inlet vacuum hose will cause fuel to flow from the tank.
Choke unit (enricher) will extend out and retract when I connect it direct to a car battery.
Exhaust is sooty inside.
Drivetrain all looks to be free moving, I wondered for a while if the drivetrain was stuck, but apparently not.
The inlet elbow is not cracked. The spacer underneath isn’t great, it looks to have been overtightened in the past. It doesn’t have any cracks that go all the way through.
I've not looked at this before, so any cracking predates our ownership of the moped.
The vacuum lines to inlet and from airbox are dry, have no fuel in them.
Things I have tried:
Closing fuel/air ratio screw fully (clockwise): still idles, still won’t rev up.
Opening up the current carb and blowing compressed air through all jets and tubes.
Swapping in a spare plug, probably the original one, not new. Makes no difference. Gap on this one is the same, 0.63mm.
Disconnecting vacuum lines, makes it worse, and unable to maintain idle.
Swapping in a brand new Keihin CVK PD18J carb and autochoke and makes no difference, difficult to start and won’t rev up.
Disconnecting air filter at the carb inlet improves throttle response very slightly.
Trickle charging battery to ensure best charge.
Disconnecting exhaust at the three bolts. Makes it louder, doesn’t help with revving up.
Spraying starter fluid around inlets and hoses, doesn’t affect running.
Reducing valve clearances down to 0.05mm, probably made it worse, in that it would rev up even less.
Other information.
This machine has history. When I first checked the valve clearances, because it was surging and cutting out, the clearances were hard zero.
I had a badly routed vacuum hose to the air inlet a while back which resulted in it cracking originally, so I shortened it and rerouted it. That then came off the connector at a later date so I replaced it with a 3mm internal diameter vacuum hose from the parts shop. This is a different internal diameter, the original was I think 4mm. I don’t think this, or the length of this hose is important. Could I be wrong about either of these?
As I have done a complete carb/choke swap I am ruling out jets, diaphragms, needle heights, floats and so on.
My daughter doesn’t live with me and so I got reports of problems with the machine by text message, so I don’t have all the details. After the last service I did, when I did valve clearances and fixed the vacuum tube, the machine ran Ok for a few days, then as she says, died, while she was out. She spent some time trying to start it. She got it going again, enough to get home, but it has behaved as now ever since, around a month.
I don't know where to go with this, hence joining the forum. The plug and the improved running without air filter attached makes me think its running rich, but I haven't changed the jets. Swapping in the new Keihin carb doesn't resolve the running issue, so if it's getting too much fuel still could that be a petcock issue? It operates as expected, ie fuel does not flow until vacuum is applied to the air inlet hose.
Other information.
