Post by jeffreycarter87 on May 29, 2024 17:02:00 GMT -6
Need help!!! 150cc gy6 kart won’t start unless I use starter fluid, then it runs until the starter fluid burns off then dies again. I cleaned the carb, problem still present, I replaced the carb and the percock and vacuum and fuel lines. I have adjusted the valves to .004 in. I assumed a vacuum issue maybe? If I open the carb float drain plug fuel runs out. Any help of where to go to next would be appreciated. Thanks!
