yy250tt
by: rpharleydavidson - Nov 18, 2010 17:11:11 GMT -6
Post by rpharleydavidson on Nov 18, 2010 17:11:11 GMT -6
i have 2 new coils besides the original . all three run power to the red/yellow wire with key on. tested start switch, continuity to ground when button is pressed.
yy250tt
by: rpharleydavidson - Nov 18, 2010 18:20:46 GMT -6
Post by rpharleydavidson on Nov 18, 2010 18:20:46 GMT -6
tested start button, continuity to ground at red yellow when start is pushed. second test had 12 volts to green yellow with key and brake on.
yy250tt
by: rpharleydavidson - Nov 18, 2010 18:39:32 GMT -6
Post by rpharleydavidson on Nov 18, 2010 18:39:32 GMT -6
sorry, had meter on wrong setting. 11.8 volts on greenyellow when key and brake is on. no continuity to ground at red yellow when start button is pushed. battery has 12.8 volts .
yy250tt
by: rpharleydavidson - Nov 19, 2010 16:38:57 GMT -6
Post by rpharleydavidson on Nov 19, 2010 16:38:57 GMT -6
jumped green/yellow to keep power thru harness,and grounded red/yellow to battery negative. bumped brake and it turned over! finally decided to take aguess at it from your expert help and direction. took kill switch apart and found melted contacts inside along side of detent ball !! ordered new switch. to confirm diagnosis i put small screw driver against 2 run contacts and pushed start button , it turned over!! cant wait to install new switch.
