yy250tt
by: rpharleydavidson - Nov 19, 2010 16:38:57 GMT -6
Post by rpharleydavidson on Nov 19, 2010 16:38:57 GMT -6
jumped green/yellow to keep power thru harness,and grounded red/yellow to battery negative. bumped brake and it turned over! finally decided to take aguess at it from your expert help and direction. took kill switch apart and found melted contacts inside along side of detent ball !! ordered new switch. to confirm diagnosis i put small screw driver against 2 run contacts and pushed start button , it turned over!! cant wait to install new switch.
yy250tt
by: rpharleydavidson - Nov 18, 2010 18:39:32 GMT -6
Post by rpharleydavidson on Nov 18, 2010 18:39:32 GMT -6
sorry, had meter on wrong setting. 11.8 volts on greenyellow when key and brake is on. no continuity to ground at red yellow when start button is pushed. battery has 12.8 volts .
yy250tt
by: rpharleydavidson - Nov 18, 2010 18:20:46 GMT -6
Post by rpharleydavidson on Nov 18, 2010 18:20:46 GMT -6
tested start button, continuity to ground at red yellow when start is pushed. second test had 12 volts to green yellow with key and brake on.
yy250tt
by: rpharleydavidson - Nov 18, 2010 17:11:11 GMT -6
Post by rpharleydavidson on Nov 18, 2010 17:11:11 GMT -6
i have 2 new coils besides the original . all three run power to the red/yellow wire with key on. tested start switch, continuity to ground when button is pressed.
yy250tt
by: rpharleydavidson - Nov 18, 2010 12:53:32 GMT -6
Post by rpharleydavidson on Nov 18, 2010 12:53:32 GMT -6
now iunderstand the starter button grounds solenoid when activated but my red yellow is getting power thru solenoid harness. when i unplug solenoid harness red/yellow isnt powered on harness side. solenoid plugged in red/yellow has voltage . tried new solenoid and same thing. used meter on solenoid off harness and both show complete circuit thru solenoid fromgreen/yellow to red/yellow.
yy250tt
by: rpharleydavidson - Nov 17, 2010 17:10:39 GMT -6
Post by rpharleydavidson on Nov 17, 2010 17:10:39 GMT -6
first, thanks for the help. ok, new harness, no jumper wires, own multi meter.dont know what prior mechanic did toit,after 3 months he gave up. ignition switch has 6 wires red,red/white,black,black/white,brown/white,orange. brown/white and orange are not used. harness side has 4 wires, red, green, black and brown/white. red on harness goes to red on switch,black onharness goes to red/white on switch, green on harness goes to black on switch, brown/white on harness goes to black/white on switch. the red/yellow at solenoid is hot when key is on , according to dr. jr this should be ground! i tried your test and blew the fuse ,again! both brake switches work and all but light fuses are hot in fuse box. at start switch yellow/red is hot with key on and passes juice to yellow which also goes to kill switch when start switch is activated.green and black/white at kill switch are grounded. is this all correct? this scoot only has 26 miles on it and was returned to dealer.
yy250tt
by: rpharleydavidson - Nov 16, 2010 18:33:24 GMT -6
Post by rpharleydavidson on Nov 16, 2010 18:33:24 GMT -6
found melted wiring harness and wire in wrong terminal coming outof ignition harness, ordered and installed new harness. lights and horn work but motor will not turn over, have power to small red yellow andgreen yellow wires at start solenoid. is this power at solenoid with key on correct?
yy250tt
by: rpharleydavidson - Oct 24, 2010 22:21:10 GMT -6
Post by rpharleydavidson on Oct 24, 2010 22:21:10 GMT -6
put jumper wire in 2 pin harness connector of gy6 mini relay which is just behind voltage regulator. dash lights and license plate turn on even when key switch is off. power is going in to key switch but harness is missing wire where power comes outof key switch harness! what is going on here!
yy250tt
by: rpharleydavidson - Oct 23, 2010 18:13:33 GMT -6
Post by rpharleydavidson on Oct 23, 2010 18:13:33 GMT -6
26 miles on scooter. sitting on center stand,right brake handle taped down. 2008 bronc with cf moto engine
yy250tt
by: rpharleydavidson - Oct 23, 2010 18:03:44 GMT -6
Post by rpharleydavidson on Oct 23, 2010 18:03:44 GMT -6
yy250tt
by: rpharleydavidson - Oct 23, 2010 18:01:11 GMT -6
Post by rpharleydavidson on Oct 23, 2010 18:01:11 GMT -6
if i jump the two harness under the dash i can get it to turn over and crank,horn and turn signals work also but no spark at sparkplug. have removed all plastic.the two six point plug ins under dash are the ones i jumped, but if they are hooked up prperly it wont do anything. fues in fuse box are all good also the one near battery.
yy250tt
by: rpharleydavidson - Oct 23, 2010 14:02:11 GMT -6
Post by rpharleydavidson on Oct 23, 2010 14:02:11 GMT -6
250 wont start,replaced fuse near battery,battery is new and charged,starter and start switch are good. Attachments:
