Post by gy6ownsall on May 30, 2011 0:14:13 GMT -6
Out of the Box, Superior Powersports! Attachments:
Post by gy6ownsall on May 30, 2011 0:15:14 GMT -6
Mirrors on, PDI complete! Attachments:
Post by gy6ownsall on May 30, 2011 0:16:20 GMT -6
Cont'd Attachments:
Post by gy6ownsall on May 30, 2011 0:18:02 GMT -6
Painted Black, Holes drilled to help keep clutch cool, 12g rollers, 15/38 gears, Scrappydog Clutch and Drum Attachments:
Post by gy6ownsall on May 30, 2011 0:18:51 GMT -6
Uni Pod filter setup, 120 main jet Attachments:
Post by gy6ownsall on May 30, 2011 0:19:39 GMT -6
Scooter-atvparts. Free Flow exhaust, sounds nice Attachments:
Post by gy6ownsall on May 30, 2011 0:20:28 GMT -6
Engine shroud cooling scoop mod, works great! Attachments:
Post by gy6ownsall on May 30, 2011 0:23:06 GMT -6
Post by Alleyoop on May 30, 2011 0:54:49 GMT -6
Nice, it is idleing to high the Rear Wheel Should not be spinning at Idle. Also I heard little POPS when you let off the Throttle, richen it up a little with the Fuel Ratio Screw it is running a little Lean. Alleyoop
Post by gy6ownsall on May 30, 2011 11:35:16 GMT -6
Yes it was, I fixed that problem a week or so ago, thanks for the help though, The bike currently isnt running at top form, It will start and idle all day, but won't rev past 4k rpms. Anymore than 10-15% throttle and it dies immediately, no sputter just bogging all the way down. =(
Post by Alleyoop on May 30, 2011 23:34:15 GMT -6
Have you checked the Diaphgram, it may be ripped and not raising the needle out of the main jet. Did you take the carb apart may you did not put the Rubber Diaphgram on in the groove on top of the carb and it is leaking. Alleyoop
Post by gy6ownsall on May 31, 2011 16:48:03 GMT -6
ALLEYOOP YOU ARE THE MAN. the tapered needle came off of the c-clip in the diaphgram. thank you good sir. I actually came back inside and hopped online to thank you just as I saw the needle sitting down in the carb while the diaphgram was out. I will now return to the garage and see if i cant put it back together. thanks once again
