Post by Cruiser on Jun 21, 2011 12:00:27 GMT -6
Where is that one located and how do i access it please? Follow the heavy red wire coming off the battery until you find a fuse. That's the main fuse.
Post by Cruiser on Jun 21, 2011 12:04:57 GMT -6
So what if there was no main fuse and I got a short. What would be hit first? If the main fuse was missing, nothing would happen. If the main fuse was bypassed (a jumper wire or wiring installed without a proper fuse) then a couple of things. 1. Melted wiring which may burn itself open. 2. Melted wiring which may cause a fire and destroy the scoot. Either case - a very expensive fix.
Post by esauhi on Jun 21, 2011 17:12:07 GMT -6
So on the entry side of it, where the red wire from the battery comes in, I get power, but nothing on the other side. I did a continuity test on the fuse and it bipped. So would that mean that the box fried? Also, is that the disaster box? Attachments:
Post by esauhi on Jun 21, 2011 17:18:24 GMT -6
I also tested those and that's what I get. Anywhere else there is nothing. Attachments:
Post by Alleyoop on Jun 21, 2011 18:54:11 GMT -6
Question? is that your RELAY? Does it have two Terminals one Black cable going to the starter and the other the RED Positive from the Battery? Alleyoop
Post by esauhi on Jun 21, 2011 19:03:19 GMT -6
Yes it does. Except on mine they're both red.
Post by Cruiser on Jun 21, 2011 19:08:03 GMT -6
You are measuring across the main fuse which appears to be open. Here's what the fuse looks like out of the fuse holder: www.minute-man.com/acatalog/Blade_Type_Fuse_ATO_ATC_Fuses.htmlGrab the plastic edge and pull it out of the fuse holder and it should read 15 or 20 on the edge. Replace with the same value fuse and let us know what happens.
Post by esauhi on Jun 21, 2011 21:06:08 GMT -6
Yep! Power in, but no power out.
Post by Alleyoop on Jun 21, 2011 21:24:43 GMT -6
Well that is some good news, you just might need a new fuse. Alleyoop
Post by esauhi on Jun 21, 2011 21:39:50 GMT -6
But the fuse was good though!
Post by Alleyoop on Jun 21, 2011 21:44:22 GMT -6
You just said it was good going in from the battery but nothing out?
Post by esauhi on Jun 21, 2011 22:15:24 GMT -6
Yes! And also, I did use a wire and jump the two red wires coming out of it and it in fact cranked my starter up. So does that mean that I have to replace that relay? And also if after that everything works out, how would I connect so that I don't have to use that stupid alarm?
Post by Alleyoop on Jun 21, 2011 22:57:00 GMT -6
Well lets tackle one thing at a time.
1. You checked if Juice was flowing from the batter to the FUSE (IS THAT CORRECT)? 2. THEN You said on the other side of the FUSE nothing (CORRECT)? 3. If you say yes to #2 then you FIRST NEED TO REPLACE THE FUSE. Then try to start it and see if the Start BUtton works for you. For now leave the Alarm lets first get the scoot to start. Alleyoop
Post by esauhi on Jun 22, 2011 9:48:06 GMT -6
Ok! Great news!!!!!! On that lil black box, there were two fuses. A 20A replacement and a 20A that was hooked. The hooked 20A was in the back of it and I couldn't see it, so I got confused. SO now I got power back to the system and it even light up and crank without the alarm box hooked. But It didn't start. So I don't know if that normal since it's been sitted for the last 4 days. SO is there anything else that I need to do now before attacking that alarm box and finally the valves adjustment?
Post by Cruiser on Jun 22, 2011 11:14:12 GMT -6
Congratulations! It looks like the removal of the alarm did not affect the starting function after all, like I mentioned earlier. If the valves do need adjustment, it will make the scoot hard to start.
