Post by skytex on Jul 2, 2011 8:12:19 GMT -6
Title says it all. Is there a way to calibrate the speedometer on these icebears?
Post by Alleyoop on Jul 2, 2011 10:50:05 GMT -6
Mine is mechanical and is very accurate, but in the bright sunlight I could not see it clearly so I put numbers on the outside from 0-6 and can now see what my speed is at a glance. You could do the same thing to indicate your real speed. Some have taken the plastic cover and put the numbers right on the dial. The digitals are off like 8 mph to high, Wildman found that out on his -11 trike. Alleyoop
Post by skytex on Jul 2, 2011 11:36:42 GMT -6
Mine is the all digital gauges though.
Post by parsonsj11 on Jul 2, 2011 12:35:36 GMT -6
Post by mike6736 on Jul 2, 2011 16:32:12 GMT -6
The Magnum is only 4 miles off....easy to get used to.....
Mike
Post by parsonsj11 on Jul 2, 2011 23:48:42 GMT -6
mike mine is 10-15 off. i got it up to 55 on one of my checkouts(GPS Speed) and speedo said 74..... this one is fully setable so get dead on with GPS..
plus like i said it gives ya a bar graph and numbers Tachometer to boot.
Post by mike6736 on Jul 3, 2011 11:13:58 GMT -6
parsonsj11 I have seen them at the ATV sop here. Yoou know in the day time I can not read the GPS sun is to bright I have to listen to the thing for my turns....I was thinking of one but worried I could not read it. Am going to get a tach tach but will be with the round gage and the hand so I can read it easly.
Mike
