Scoot over, and he means it!
Post by scootover on Aug 16, 2011 17:25:47 GMT -6
It would work intermittely, now it wont work at all. I took apart the switch assembly and got to the horn button and contacts. I cleaned the contacts, and the surrounding copper contact spring disc, still nothing. It only has two wires to to the switch, even if I jump across them, it still dont "beep". Any suggestions? I cant have a forum name like ScootOver, if my horn dont work. Yelling at the idiot that pulled out in front of me today, only made me feel better. Scootover................and I mean it!
Post by Alleyoop on Aug 16, 2011 19:33:23 GMT -6
Did you check the actual horn, it may not be grounded or one of the wires came off the Horn itself. It may not be your switch at all. Alleyoop
Post by scootover on Aug 16, 2011 20:08:26 GMT -6
Where is it located, I havent found the horn or the relay for it, if it has a relay. I know it has a horn............it worked a few times, but I have been riding it, and now........no horn, so where is the dadburn thing located?
ScootOver
Post by Alleyoop on Aug 16, 2011 20:11:08 GMT -6
Look under the front fender you will see it right away it is out in the open right by where the Front shocks go into the tree. Alleyoop
Post by scootover on Aug 16, 2011 20:54:05 GMT -6
Alley; I will have to keep looking, it aint out in the open at the tree where the forks are. I know it has one, cus it was working. Any other suggestions...............anyone? ScootOver.............I'd honk...........but my horn aint working!
Post by Alleyoop on Aug 16, 2011 21:23:03 GMT -6
Here is my Horn see the round silver with red. Alleyoop
Post by scootover on Aug 17, 2011 12:39:48 GMT -6
Ok Folks.... Here it is. I called Jim at Rapid Repair. Thanks Jim. On the 150-11 style trikes, the horn is under the front nose cone and windsheild. Jim has pics of hot to get to it on Scoot Dog. The connections were real soft aluminum, and wouldnt stay tight to keep the horn working. I changed the ends on mine, but them back on the horn.........VIOLA! I now have a horn.......but its sure is hidden. Thanks again Jim! ScootOver.................and I mean it! Cus I got a horn now, and you WILL get..............horned! Or is that beeped.........hmmmmm.
