2009 ICE BEAR PST150-11 SUPER TRIKE
Post by wildman on Oct 21, 2011 12:00:52 GMT -6
Here's a question for you electrical savy folks... Is it possible & if so how might i go about hooking up an automotive Tach & Dwell Meter to a scooter or motorcycle for use of the Tach function just for mechanical purposes??? The bike doesn't have a tach & I don't want to put one on it ether, but I need to see what it is idling at, also need to set the rpm for timing & timing advance diagnostic purposes... I have a Tach/ Dwell Meter for 4,6, & 8 cylider engines w/ 2 leads connection... Hooks to coil ground (points system) or tach terminal (CDI system) & chassis ground... Can the mathematical formula used w/ meter reading be changed to calculate the rpm for a 2 cylinder engine instead of 4,6, or 8 cylinders...
David Sr.
Post by Alleyoop on Oct 21, 2011 12:21:04 GMT -6
Wildman, I did find this: Alleyoop
if the outboard has one coil and set of ignition points, then for a 2-cylinder 2-stoke you would multiply the 8-cylinder rpm reading by two
So, with the tach/dwell on one set of points, multiply the 8-cyl rpm by four. Each 2-stroke cylinder has one "ignition event" per revolution; an old-time 4-stroke V-8 would have four events per revolution.
