Post by darla on May 21, 2012 14:54:13 GMT -6
I rode the scooter for approximately 45 minutes and pulled into the garage, turned it off, got off of it and noticed a pretty good gas leak. It was running fine. I need simple instructions on how to fix this since I know nothing about fixing pretty much anything. Any help is greatly appreciated.
Post by Alleyoop on May 21, 2012 15:07:54 GMT -6
is it leaking out of a hose right in front of the CVT cover. If so that is the CARB DRAIN HOSE. And it the hose is wrapped around with a wire the END of it has a SCREW. You probably lost the Screw from vibrations. To Stop the fuel from coming out BEND the HOSE and ZIP TIE so no fuel comes out Or you will need to take the fuel hose off the carb, take it to a hardware store and get a screw that will fit the end of it. Alleyoop
Post by Bashan on May 22, 2012 4:04:57 GMT -6
Wow, nice pic Alley. The carb float could also be stuck. If it's leaking out of the short hose coming right off of the carb (see Alley's pic) that's what it is. Rich
Post by darla on Jul 16, 2012 19:52:21 GMT -6
Thank you Alleyoop! That's the best answer to any question I've asked.
