Post by ironworks on Jul 15, 2012 17:17:31 GMT -6
does anyone now where i can get a rebuild kit for the rear differential on my 2010 ice bear compellor. like bearings gears gaskets seals and so on. the rear differential is making some very loud noises on deceleration when riding like something came loose inside or a bad gear or bearing. this trike has the rear differential that has reverse in it not in the trans.also it is not a cable adjustment because i have put lever on rear differential all the way as far as it can go for forward and it still is making some realy bad gear noises. i thought maybe there is someone that has taken one apart and found out the problem maybe a loose nut or bad bearing or a shaft that was not shimmed correctly.anyone with info would be great
ps also where i can get these parts when i need them.
thankyou iron works
Post by Alleyoop on Jul 15, 2012 18:25:31 GMT -6
I believe MIKE6736 has some experience with that one, he got replacement gears for his cause they were making a nasty noise. To get new gears and stuff you have to go through your dealer they will order them for you. I am sure he will chime in or you can PM him. Alleyoop
Post by ironworks on Jul 15, 2012 19:47:07 GMT -6
hey alleyoop thankyou for info. if you talk to mike let him know i am looking for info. also i can probably order parts through jim correct?
Post by Alleyoop on Jul 15, 2012 20:47:16 GMT -6
I just pmed him maybe he can help with some info on that differential, i have the straight axle which is different.
About ordering I don't know you will have to talk to Jim or pm him. Alleyoop
Post by mike6736 on Jul 15, 2012 22:11:12 GMT -6
Yo Iron.... I thought the compellor had a different rear that the Magnum, but if the rear takes gear oil and the reverse is on the top it is most likely the the top gear. Best thing to do is have Jim order replacement gears for you be sure to get the gaskets also. I checked my first gear box and all the bearings were OK. The bad gears were the top 3 gears and the rear sprocket spline shaft was damaged were the sprocket rides, if yours is get a new shaft also or have it weld and grind. Bearings if needed can be got from local parts stores. I have not rebuilt my spare yet but looked into it and can see how the shifter gear did all the damage. I have a new set of gears from IB that are supposed to be harder than the old. I will rebuild it and install it when I can figure a better way to align and lock the rear axles section and use a chain tension-er. I think the old set up just moves too much.
Mike
Mike
