This trike you fly!
regrets
by: new2scootn - Oct 4, 2012 20:55:35 GMT -6
Post by new2scootn on Oct 4, 2012 20:55:35 GMT -6
Glad you're ok daddue11, I think I'd be shaken and mad as hell too. You made me take a close look at my engine support "crossmember" and I found I had about a 1/4 inch of play in the rear wheel side to side. So you know me, I had to tear her apart and see what's what. It took some doing and I'll post some pics on how I did it tomorrow but I got that stinkin' crossmember out to look at it. It doesn't have bearings in it, its made like a bushing(inner tube surrounded by rubber. Here's a pic of the thing. Mine doesn't look bad but the bolt that goes through it doesn't fit tightly, it has some slop. I'm curious as to what part actually failed, the bushing the long bolt goes through, one or both of the upper bushings that attach to the frame, or the bushings/bearings that are attached to the motor that the long bolt goes through(the ones in this pic). These are probably the most important bushings on this thing 'cause it's only this crossmember and the rear shocks that keep the motor, transmission, and rear wheel attached to the trike. So any info you can give me would be greatly appreciated-thanks.
regrets
by: daddue11 - Oct 5, 2012 7:07:38 GMT -6
Post by daddue11 on Oct 5, 2012 7:07:38 GMT -6
Hello friend,I'm gonna try to take the panels off this weekend and see for sure what exactly went kapoot with the part or parts buddy. I'll be sure to take pics and post.thanks for the pic,that helps millions.
This trike you fly!
regrets
by: new2scootn - Oct 5, 2012 8:27:01 GMT -6
Post by new2scootn on Oct 5, 2012 8:27:01 GMT -6
Daddue11, you won't have to take any panels off, just remove the battery tray under the seat and move to the side and you'll be able to see everything. I'll post tonight how to remove the crossmember.
regrets
by: daddue11 - Oct 5, 2012 20:12:30 GMT -6
Post by daddue11 on Oct 5, 2012 20:12:30 GMT -6
You got it. I've been gone to meetings in St.louis yesterday and Springfield today,I just got back ten minutes ago,gotta get some sleep tonight,so tired. Thanks again.
