Post by Alleyoop on Jun 25, 2012 23:39:37 GMT -6
Here is what I used on my Trunks wing, I installed a 9" LED strip of lights it comes with two wires one hot and one ground. Then I ordered this Dual Element Circuit Spliter. Dual Element Spilter: www.chromeglow.com/catalog.asp?prodid=520657 Quick Connectors: LED STRIPS: www.ebay.com/itm/RED-24CM-LED-Strip-waterproof-Car-Auto-Flexible-Grill-Light-Lamp-Bulb-12V-New-/251165838861?pt=US_Car_Lighting&hash=item3a7aa68e0dUse the Quick connectors and just connect one to the BROWN Running light wire and another to the GREEN&YELLOW Brake Light Wire right by the Bulbs and then connect one end of the Dual Element to each connector and the LONE connector to the LED strip and your done it is a piece of cake. You connect the single lead to the LED HOT and Ground the LED Ground Wire then the other two Splice one to the Brake Light Wire and one to the Running light Wire and your done. You will have nice bright running lights and all the LEDS come on nice and bright when you squeeze the break. Alleyoop
Post by Alleyoop on Oct 15, 2012 13:33:22 GMT -6
Updated with pictures and HOW-TO Alleyoop
Post by Alleyoop on Oct 15, 2012 18:11:58 GMT -6
Very Cool Terrilee, nice job always good to have as much lighting on the rear as possible so when your riding they can see the lights in front of them and hopefully not run your arse over. Alleyoop
