Post by ironworks on Oct 28, 2012 14:44:27 GMT -6
alley or mike do you guys know the part # of the seal that go behind the rear brake rotors.i am getting ready to change out my rear differential and replace it with a new unit from jim from rapid repair. jim wanted me to get the part # off of the old seal so he could get me two new ones.i dont have a problem with that but it will be stuck on my lift when im waiting four the new ones.so thats why i thought maybe by chance you mike might know seeing you replaced your rear differential already.
thankyou guys in advance for all the help. ironworks
Post by Alleyoop on Oct 29, 2012 22:39:13 GMT -6
Are you talking about the RUBBER DUST SEAL that fit on the end of the AXLE where the HUB goes in? that is a straight axle job and the only seals I know of are the RUBBER DUST SEALS. If they are the RUBBER DUST SEALS you really do not need new ones they do not wear out. They just sit there they do not turn and the HUB fits right in there. Alleyoop
Post by mike6736 on Oct 30, 2012 18:17:44 GMT -6
Mine is totaly different than yours Ger Magoo
