Post by Alleyoop on Oct 30, 2012 21:24:27 GMT -6
I have the 157QMJ motor on the Trike and have always been getting Kickbacks when I start my Trike with the performance CDIs. And more so after the Big Bore Kit and 2+2 Stroker Crank due to the high compression, It sounds nasty like the Starter Clutch gears or Starter Gears are going to break. I bought other Performance CDIs and they all caused Kickbacks and the only one that did NOT KickBack was the OEM Standard CDI which DOES NOT have advanced timing. So I was googling for a CDI that would be retarded at low rpms and advance the timing as your RPMS RISE. Well I found one that sounded promising and was going to order it and try it out. I First asked JOHN our TVANCMAN if he had one or if he could get me one. He said yes which one did I want and sent me a list and pictures which had a short description. I told him which one I wanted the GY6 AC Advancing Angle Performance CDI. They come in different colors by different manufactuers etc.. I just picked one of them and I am a happy camper no more kickbacks and a little more power to boot. Well John got the shipment in and sent me the CDI, I immediately put it on. Well It is FANTASTIC!! I hit the start button and it immediately Fired up NO KICKBACK and get this it IDLED at 1100rpms!! I had to raise the Idle to 1500rpms. The sucker idles really smooth I go by the MIRRORS if they Vibrate or not(HAHA). I naturally pulled the trike out and cranked a little just around my neighborhood It was cold and windy and I did not bother to put on my helmet or jacket just in my short sleeve shirt. It is GREAT!! Just what I was hoping for here is what it looks like: Alleyoop
Post by justincrediblem on Oct 30, 2012 22:33:46 GMT -6
I get kickbacks when starting mine. When I was having my ignition coil problem the mechanic was telling me I had a bad cdi which was causing the kickbacks. Is my CDI possibly a cause for my speed issue? Good to hear alley!
Post by Alleyoop on Oct 30, 2012 23:34:00 GMT -6
Yes, the CDI may not be letting it get up in RPMS. Alleyoop
Post by tvnacman on Oct 31, 2012 8:06:00 GMT -6
The cdi is controlling the ignition timing. Seems as if Alley has found the cdi that has the correct curve for his engine setup.
