Post by lv2tnchick on Dec 4, 2012 16:11:37 GMT -6
Need Help!!!!
I recently bought a 2008 Roketta Scooter! 150cc.
First problem: electric start won't work, so I use kick start. Lately, I can't get the kick start to go. After 10 times of trying or so, it will finally start, but only if I am holding the throttle back. Should it be that much of a problem?
Second problem: I was driving and as I tried to accelerate it, it just popped and stopped accelerating.
I need help for this is how I get to and from work and school. I need the least expensive way to fix, but also way that will fix it for a good amount of time at least!
thanks!!! :)
Post by Alleyoop on Dec 4, 2012 16:28:03 GMT -6
When you say POPPED was it the motor making popping sounds or somthing else. Does the motor start and run but does not move? Alleyoop
Post by lv2tnchick on Dec 5, 2012 7:24:53 GMT -6
When I say popped, the throttle itself stopped pulling back. It will run as far as I know, but gets no acceleration.
Post by justbuggin on Dec 5, 2012 8:29:51 GMT -6
sounds like you may need a new thottle cable does the grip turn freely or does it sping back put the bike on the center stand start it does the rear wheel spin when giving gas and does the engine rev up when given gas it could also be the belt has broken let us know what happens with these test and that will help to pin point the problem
Post by Alleyoop on Dec 5, 2012 13:34:25 GMT -6
Yep, sounds like the throttle cable broke. Check by the Throttle Control Wheel on the Carb and twist the throttle grip and see if the Throttle Control Wheel Turns if it doesn't the cable is broke. Alleyoop
Post by lv2tnchick on Dec 6, 2012 10:56:28 GMT -6
I had a friend of mine look at it! He said that a piece is broken near the throttle. Where can you buy Roketta 2009 150cc pieces? Thanks!
Post by justbuggin on Dec 6, 2012 23:56:25 GMT -6
any of the ad that run at the top of the board good luck and ride careful
Post by lv2tnchick on Dec 9, 2012 20:15:43 GMT -6
Thanks!
