Post by learae on Mar 31, 2013 11:45:03 GMT -6
Post by Alleyoop on Mar 31, 2013 12:05:33 GMT -6
It is the same thing the Valve is down the line on that one but they are the same. I can see the valve is not built into the valve cover but just the pipe coming off of it. Follow the pipe and along side the motor and you will see the valve and a Vacuum line going to it. I think I have a shot of one with that configuration. Alleyoop
Post by Alleyoop on Mar 31, 2013 12:09:55 GMT -6
I found this one which looks like what you have. At the end of the PIPE it has a rubber hose to connect to the Valve. Alleyoop Going into something like this or a canister:
Post by learae on Mar 31, 2013 13:53:50 GMT -6
ok well problem: solved.
Post by learae on Mar 31, 2013 13:54:28 GMT -6
And the inside is smooth, the outside is chewed up from clamping. Gosh I need to get myself a shop.
Post by Alleyoop on Mar 31, 2013 14:15:52 GMT -6
Good job, as long as it blocks the hole who cares what the outside looks like. Make sure the Vacuum line that was used to activate it is plugged up by its ORIGIN. Alleyoop
Post by learae on Mar 31, 2013 14:21:10 GMT -6
Thanks for the help I got the valves set (they were way too big) and once I get the carb back in I am going to try to fire it up!
Post by Alleyoop on Mar 31, 2013 14:28:51 GMT -6
Sounds like a plan, hope it comes to life and purrs like a kitten, if not we can then adjust the carb. Alleyoop
Post by justbuggin on Mar 31, 2013 16:52:05 GMT -6
wow i did not mean to start a ruckus just that it was part of a smog system which all of the above system fall under and that it can be removed and that the holes that it was attach to needed to be plug off
Post by Alleyoop on Mar 31, 2013 16:57:17 GMT -6
No ruckus Justbuggin, all is well. Alleyoop
Post by drifter on Mar 31, 2013 20:55:46 GMT -6
i APOLOGIZE FOR DISRUPTING THE FLOW OF THOUGHT HERE, I THOUGHT THE GOOD FELLAS QUESTION WAS ANSWERED
I had thIS sort of EPA deal, it is serious stuff to control as a fire can come from not shutting it down right.
by far the best is the NCY custom shut off GASKET.
On mine i removed everthing but the metal tube coming off the head, I took the rubber tube coming off that and bent it over and zip tied around it and the metal tube about 4 times.
WHAT MANY FOLKS MISS REMOVING THIS THIS -
on some systems, that device also bleeds back to the air filter, if you remove it, it leaves a hole past the filter that allows dust right down your carb air intake, you can get a big screw and cover it with epoxy, and screw it into the hole in the factory air filter.
after doing all this RIGHT, adjust valves and AF screw, cause you have changed much about air and exhaust currents
BE VERY CAREFUL, THEIR IS AT LEAST ONE CASE OF A BIKE THAT CAUGHT ON FIRE FROM THIS THING BEING MODED WRONG, WHAT EVER YOU DO, TAKE PICS AND GET 2ND SET OF EYES HERE TO HELP.
cheap white metal sheet will erode slowly, pick a engineered metal
Post by Bashan on Apr 1, 2013 5:10:27 GMT -6
I see the one line running to the check valve and up to the gas tank in your picture, but where do the other two lines go? The idea is that the vacuum from the airbox draws vapor off of the gas tank when the vac valve opens. The problem is the check valve lets gas through if the bike tips over, or sometimes the canister gets plugged. When this happens you lose your tank vent and the bike stalls.
