Post by Alleyoop on Aug 18, 2013 11:53:13 GMT -6
Have you opened it up and get it to its max speed? The rpms should be in the 7K range If not then your weights are to Heavy and you should get 12 gram weights that should make it run around in around the 7K range and not have the motor screaming at you and your mph should be around 50mph. Alleyoop
Mission Tx.
Post by kalee on Aug 19, 2013 17:10:15 GMT -6
Okay, Thanks Alley I will have to try that and see what I get kalee
Mission Tx.
Post by kalee on Aug 20, 2013 7:43:59 GMT -6
Alley,,, Took my trike out this morning and at 50 Mph its runin 6100 Rpm & at 55 Mph its runin at 7150 Rpm's. I shut it down after I had settled in at 55 mph not sure what the top end is yet, dont know if that would hurt the enigine or not, I have 205 miles on the trike. kalee
Post by Alleyoop on Aug 20, 2013 8:41:00 GMT -6
WOW!! I would no touch it if it runs like that, Those are GREAT NUMBERS RPMS WISE as well as speeds. DO NOT FIX WHAT IS NOT BROKEN. No it will not hurt the motor The 150s the REDLINE is 8000 rpms but that is screaming Your are right at where you want to be TRUST ME your trike is running better than 99% of any trike owner(EXCEPT MINE OF COURSE..HAHAHA). Alleyoop
Mission Tx.
Post by kalee on Aug 20, 2013 10:33:16 GMT -6
Thanks,, Alley that makes me feel better knowing its pretty well up to par, I'm SURE yours will more than outdo mine but thats okay for now. Thanks again kalee
Post by Alleyoop on Aug 20, 2013 10:59:03 GMT -6
Well don't forget I have 30more ccs than yours but when it was stock and I just put on a performance variator and changed weights It ran like yours. Alleyoop
Mission Tx.
Post by kalee on Aug 20, 2013 13:29:54 GMT -6
Apparently Ice Bear has made some minor upgrades then to make these trikes run that good. Like I said earlier I have not had it wide open yet ( except for take off ) I have to ride about 5 miles to get where I can run 50 to 55 mph a lot of the speed limits here within the city limits are 45 but that isnt enough. Thanks again for the info kalee
Post by Alleyoop on Aug 20, 2013 13:42:04 GMT -6
Same here 30-35-45 speed limit streets, but here everyone goes 5-15 mph faster than the posted speed so on the 45 mph streets they are doing 50-60 anyone going 45 gets passed in the other lane(HAHA). Alleyoop
Mission Tx.
Post by kalee on Aug 20, 2013 14:46:19 GMT -6
Yeah they do the same thing here run about 5-15 over the speed limit and once in a while some one gets a ticket just have to look out for our selves when were riding. kalee
Post by mike6736 on Aug 20, 2013 21:16:37 GMT -6
Kalee check it with a GPS if you have not, the speedo is off on these things. But one way or another that 150 is Boss...
Magoo
Post by Alleyoop on Aug 20, 2013 21:26:42 GMT -6
HEY HEYT HEY I thought mine was BOSS ![:'(](//storage.proboards.com/3059616/images/R0TobELgJ76YW_2xvHho.gif) Alleyoop
