Post by redroush00 on Oct 11, 2013 19:30:47 GMT -6
Per Alleys advise I swapped out 3- 5gr sliders and put in some 6grs. Ive got my RPMS down now below 8000 at all times. The trade off is slightly slower acceleration.
What will a performance variator do for me? WIll it raise the RPMS back up or will it give me better off the line and keep rpms where they are at?
2013 Sinnis Spirit 125cc
Post by sjrainsford on Oct 12, 2013 4:13:13 GMT -6
They have a different ramp so stop the weights from flying out so quickly, which causes you to use slightly higher rpms during take off. So that will put you back a step. If your take off is being affected by the heavier weights then maybe it suits the engine to jump just over 8k? Perhaps mix 6 and 5 gramme and see if that tunes it slightly nicer?
My recently fitted performance variator has given a few hundred rpm more during acceleration and in my case the most noticeable change is the higher top speed for a given rpm.
