Post by jamesissopro on Oct 23, 2013 12:00:07 GMT -6
I have a 50cc peace sports scooter with what I believe is the gy6. Well I took it to work the other day and heard a knocking. After checking the dipstick I noticed I need oil, there was nothing on the dipstick. After filling it up and running it a little there was no more knocking. Took it out the next day again and no oil. The leak was off the bottom of my belt housing/gearbox. It is not gear oil as that was full and I can smell the difference. After taking the belt housing cover off there was definately oil in it but I cant find where the leak is. Any advice or ideas?
Post by Alleyoop on Oct 23, 2013 12:19:40 GMT -6
Yes, it is most likely your CRANK OIL seal you will need to take the Variator off and replace the seal piece of cake to fix. Alleyoop
Post by Alleyoop on Oct 23, 2013 12:35:16 GMT -6
Post by jamesissopro on Oct 23, 2013 12:41:08 GMT -6
I did take off the variator and I dont see any seals or even wwherethe leak is. I have everything out of the belt housing. Ill post pictures in a few minutes. I am probably going to have to put everything back together and run it til it leaks again...
Post by jamesissopro on Oct 23, 2013 12:43:33 GMT -6
I filled it with oil again and havent been able to get it to leak again all morning. I had it run sitting still but ill probably tak e it around the block.
Post by jamesissopro on Oct 23, 2013 13:49:59 GMT -6
So this is what is leaking it appears, the bearing or seal around the crank shaft has a minor leak, I put 5w instead of 10w in it last night to get it home so that might be why it completely drained. Now how do I fix that. Also, after reassembling everything it feels like the power isn't being fully delivered to the wheel. It accelerates a little slower and feels jumpy (The feeling you would get in a manual car when you hit the clutch to shift.)
Post by Alleyoop on Oct 23, 2013 14:12:20 GMT -6
You have to get the seal out just pick at it but try not to scratch around the case and just pull it out. You can get seals at SCRAPPY DOGS.
Reason the scoot is not moving so good is the OIL is on the belt and the pulleys and it is slipping I know cause it happened to me. So when you get the new seal make sure you clean the belt and the pulleys and get that oil off. Alleyoop
Post by jamesissopro on Oct 23, 2013 14:36:48 GMT -6
Thanks very much, when I get everything back to running good I will come back here and let you know! =D otherwise I will be back with more questions. Lol.
Post by redroush00 on Oct 23, 2013 17:19:41 GMT -6
Its been recommended by car mechanics that when belts get contaminated with fluids to just replace them. Might just get another belt.
Post by Alleyoop on Oct 23, 2013 17:53:10 GMT -6
Yea, Car mechanics get a cut for every piece of extra stuff they get you to buy, they lie a lot.But this SCOOTER MECHANIC say BOO-YA, get grease cleaner and your all set. Alleyoop
