Post by bleeducci on Oct 8, 2015 21:45:35 GMT -6
And I adjust the carburetor thanks again.
Post by bleeducci on Oct 8, 2015 13:46:57 GMT -6
I try the idle screw all good now. Thanks a lot.
Post by bleeducci on Oct 7, 2015 21:40:11 GMT -6
I'm from Cyprus. When the engine is hot its starts OK. But rpm is shaking up and down. It was 2000rpm steady. Now it drops to1.5 then goes to 2.2 And the weather didn't change to much its like from 40° to 30° And don't know how adjust the carb without taking it of, because the bolt is on the bottom side.
Post by bleeducci on Oct 7, 2015 14:42:45 GMT -6
Sounds like the carb just needs a little adjustment due to Weather change. If the temps have dropped the motor needs a little more gas so try adjusting the Fuel Ratio Mixture screw, 1/4 turns at a time COUNTER CLOCKWISE. In cooler weather the motors need more gas and in hot weather they need less gas. Alleyoop Its pretty hot here but I will check it and let you know.
Post by bleeducci on Oct 7, 2015 12:56:04 GMT -6
Never had that before. When I start engine it won't start without gas, if I let the gas engine drop rpm and die , after I work the engine little bit its all fine. Any suggestion would be nice. BTW yy250t engine.
Post by bleeducci on Oct 5, 2015 21:53:34 GMT -6
Thank you. You are great dude.
Post by bleeducci on Oct 5, 2015 15:10:32 GMT -6
Its not Gona cause problem to my engine is I put 18g sliders?
Post by bleeducci on Oct 1, 2015 22:55:58 GMT -6
Hello I need help. What sliders do I need my stock was 25g a friend told me that better to put 18g is that safe or will cause some problem? The scooter is all stock nothing changed on it.
Post by bleeducci on Sept 22, 2015 21:04:40 GMT -6
Thanks a lot.
Post by bleeducci on Sept 22, 2015 15:06:27 GMT -6
Can anyone help me find parts for this scooter I'm EU citizen.
Post by bleeducci on Sept 11, 2015 22:26:15 GMT -6
Thanks.
Post by bleeducci on Sept 11, 2015 20:35:40 GMT -6
Can anyone tell me how many ml of gear oil do I put?? Thanks.
