50cc oil leak
by: dirtyredbull - Sept 23, 2015 21:01:44 GMT -6
via mobile
Post by dirtyredbull on Sept 23, 2015 21:01:44 GMT -6
The conversion mounts are expensive but they have them. thank u but can I get motor mount with out stretching it???
50cc oil leak
by: dirtyredbull - Sept 21, 2015 18:52:34 GMT -6
via mobile
Post by dirtyredbull on Sept 21, 2015 18:52:34 GMT -6
CLICK ON THE PICTURE SO YOU CAN SEE IT BETTER. thank u I actually watched that video y rings don't have those letters to put up so I just put in hope I'll see something wrong I looked again looks like coming out exhaust gasket I looked good at gaskets And else where I'll check again tonight thank u for all I'll be in touch I wanna out a 150cc motoring my 50cc scooter but 150cc motor mounts on top where can I get a adapter to make 150cc mount on my frame
50cc oil leak
by: dirtyredbull - Sept 16, 2015 12:19:06 GMT -6
via mobile
Post by dirtyredbull on Sept 16, 2015 12:19:06 GMT -6
50cc oil leak
by: dirtyredbull - Sept 16, 2015 8:41:12 GMT -6
via mobile
Post by dirtyredbull on Sept 16, 2015 8:41:12 GMT -6
Well sorry to say but it's your rings. If it was your exhaust valve it would leak when cold and throw out smoke when started but will stop after it warms up. Leaking that bad it's the rings. Alleyo op Thank u I'll take apart and look put gaps apart not in line And all someone said I had to line up with some pin I put all rings in like should won't no letters to indicate which way is up like most u have e any advice bro And no smoke when started none hard to start having e to use starting fluid
50cc oil leak
by: dirtyredbull - Sept 16, 2015 8:39:56 GMT -6
via mobile
Post by dirtyredbull on Sept 16, 2015 8:39:56 GMT -6
Well sorry to say but it's your rings. If it was your exhaust valve it would leak when cold and throw out smoke when started but will stop after it warms up. Leaking that bad it's the rings. Alleyo op Thank u I'll take apart and look put gaps apart not in line And all someone said I had to line up win some pin I put all rings in like should won't no letters to indicate which way is up like most u have e any advice bro
50cc oil leak
by: dirtyredbull - Sept 15, 2015 20:02:23 GMT -6
via mobile
Post by dirtyredbull on Sept 15, 2015 20:02:23 GMT -6
It could also be the Valve cover gasket is leaking at the bottom and it looks like the oil is coming out of the exhaust. it's not leaking from valve gasket stays dry there
50cc oil leak
by: dirtyredbull - Sept 15, 2015 20:01:15 GMT -6
via mobile
Post by dirtyredbull on Sept 15, 2015 20:01:15 GMT -6
It could also be the Valve cover gasket is leaking at the bottom and it looks like the oil is coming out of the exhaust. thank you also what to look for it looks like out exhaust gasket it's bubbling at exhaust gasket but it's tighten good what u think of piston ring gaps I thing they are right what u think?
50cc oil leak
by: dirtyredbull - Sept 15, 2015 19:59:45 GMT -6
via mobile
Post by dirtyredbull on Sept 15, 2015 19:59:45 GMT -6
you sure it's not coming out from the base gasket for the cylinder? thats the most likely spot for a new build leak thank u alot I'll start up and look again so I look at cylinder gasket or valve assembly gasket? If it is over filled Just a Lil would that make it leak what about gaps in piston rings pretty sure I did right what u think?
50cc oil leak
by: dirtyredbull - Sept 14, 2015 22:09:21 GMT -6
via mobile
Post by dirtyredbull on Sept 14, 2015 22:09:21 GMT -6
I just installed a 80cc big bore kit 50cc taotao VIP pours oil out exhaust gasket what is wrong?
