Post by feverish657 on Nov 23, 2015 18:04:11 GMT -6
Well I'm going to get some money Friday, but thinking of taking it to another shop then where I bought the trike. I know the headlight itself works turns out that the side to side method of on off is causing troubles. The shop. They replaced the battery for free once. I think my friend Carson really knows what to do. Saturday morning I will be there at his place.
Post by feverish657 on Nov 23, 2015 16:46:46 GMT -6
I never had to replace the stator cause I believed getting the battery new had done the trick. Also should a kill switch and headlight/starter switch cost me around 55$??
Post by feverish657 on Nov 23, 2015 16:43:17 GMT -6
Friday I will be getting the multi meter, but for now all I have is a trickle charger. Had no problems in the rain after they changed out the battery. How much should the rectifier cost?
Post by feverish657 on Nov 23, 2015 16:04:38 GMT -6
Just got the charger had a new battery installed and things were working well, but the headlight switch is giving me trouble so instead of using the kill switch I been just using the key and no problems. Today I have to charge the battery though. What may be the best battery to get I have a twelve volt nine amp now, anything better?
Post by feverish657 on Nov 3, 2015 17:26:47 GMT -6
I just bought an Ice Bear Mini Cruzzer and was told there is no fixing the problems I got with the rain and the stator. Is this my only option to now sell a junk trike. Tried to turn the engine over with a new battery and it still wouldn't crank. Any info please. Thank you. Or could it be the fuse by the battery or the battery in general. Should I also always buy a battery from a Napa or Auto Zone? Better quality?
