Post by tnilc on Dec 20, 2015 13:00:03 GMT -6
Thanks for the reply will check it out asap.
Post by tnilc on Dec 9, 2015 9:14:02 GMT -6
I will check the valves Tutorial Thanks I will post better pics of scooter if needed?
Post by tnilc on Dec 9, 2015 5:01:43 GMT -6
I just purchased a Neco Abruzzi with 2200 miles on the clock and when riding back from the sellers address couldnt let the neco sit in idle at the lights or it would conk out so had to keep it reved slightly with brakes on any ideas what could cause this ?
Also im going to change the spark plug, engine oil, gear oil and clean the air filter but cant figure out how to remove the side panels to access (im a complete novice :0) any TIPS....Please.
Ah and where can i buy parts? (really need a rear indicator).
Post by tnilc on Dec 9, 2015 2:02:13 GMT -6
I have Just purchased a Neco Abruzzi 62 plate that needs fixing up....im a novice and cant figure out how to get the rear side panel off so i can clean the air filter ? also can you suggest a website for parts... i need a rear indicator. Thanks.
