Post by grizzly on Jul 4, 2016 16:30:43 GMT -6
Thats not it, I left the cap off and it didn't affect it in anyway, vs the half turn which caused it to fire instantly. Does opening the screw a bit cause a little gas to pass on through to the spark plug? I think I should check my plug.
Post by grizzly on Jul 4, 2016 10:36:16 GMT -6
Alright fellas, I got a new problem for yas. I've had my scooter running better than it's ever run its entire life thanks to ya'll. BUT, about once a week or after 5-6 rides, I can't get the scooter to start at all, until I give the low fuel mixture screw a half turn to the left, then it fires right up. I'm afraid I'm going to hit the end soon and the screw will pop out.
Any ideas what causes this?
Post by grizzly on Jun 13, 2016 16:18:35 GMT -6
Ok, I'm not sure what exactly it was, but I retightened the intake manifold, and hooked the vacuum line on with a stronger clamp, and it puttered to life. After revving it for a minute or so, I slapped the seat on it and drove it down the street. It powered up to 20mph and kept the needle there steady as a rock. It sounded deeper and slower than I'm used to, so I think at this point I need to fine tune the new carb.
Thanks for the help everyone, I'll be back if tuning doesn't fix the issue.
Post by grizzly on Jun 13, 2016 15:49:29 GMT -6
I'll check it all thoroughly, the intake manifold is new as well, I ordered it before the carb and put them both on at the same time.
Post by grizzly on Jun 13, 2016 13:06:52 GMT -6
Yep, it fired right up.
I think the new carb must be the problem, since it was starting beforehand just fine, it was a performance problem.
I was checking the fuel line to be working, and sucking on the vaccuum got a steady stream of gas to come out of the line when it was off the carb, but putting the vaccuum line back on the manifold and trying to start it didn't pull any gas out into my waiting can. I also couldn't get it to start by sucking the vacuum hose manually while trying to start.
Post by grizzly on Jun 13, 2016 11:52:40 GMT -6
OK, an update. I went ahead and bought a new carb, as I didn't want to bungle around with the old one any more.
Trouble now is I'm not getting it to start at all, I'm not convinced its getting any gas, though when I hit the starter I see movement in the fuel filter, like the fuel in it is bouncing around and an bubble here and there, which I take to be a bad sign. The only things I didn't hook up were the fuel overflow hose and the drain hose, but I assume those don't go to anything.
Pulled out my spark plug and tested it on the frame, got a spark no problem.
Post by grizzly on Jun 6, 2016 23:20:06 GMT -6
It may have a carb problem,,,it happened when you cleaned it,,,,,Venturi jet may have fallen out and you didn't notice or the main jet is partially plugged I should note, the reason I even went through cleaning it was that during the winter the petcock failed and leaked through the whole system and filled up the oil.
Post by grizzly on Jun 6, 2016 23:19:07 GMT -6
Checked the Throttle cable, no wearing anywhere.
Post by grizzly on Jun 6, 2016 11:45:59 GMT -6
Apologies for the long delay.
Alright, after stupidly ordering a new intake Manifold from China, I've been waiting a full month for it to come in, and hopefully I'll see it in the next week or 2. I thought I'd be patient and save a bit of money in the long run instead of patching it, but gave up on that this week. I took off the intake and patched it per directions, though looking on the inside I don't see the cracks making it through to the other side. Still not getting it to go above 10mph.
I didn't take off the throttle cable before, but maybe adjusting it might help? On the stand it gets the power it used to, vibrating with enough power to turn the scooter in circles if I don't brace it while revving.
Post by grizzly on May 6, 2016 13:33:31 GMT -6
Perfect! I'll do that first to make sure thats my problem, though I'll ordre a new one either way.
Post by grizzly on May 6, 2016 12:55:44 GMT -6
Thanks, I was wondering if that might be a problem.
Post by grizzly on May 6, 2016 12:35:36 GMT -6
1. I did take out the diaphragm, though I was careful to put it back as it was. 2. I tried adjusting the fuel ratio screw, but only after giving it the test ride where it wouldn't go above 10mph. I gave it a half turn to the right and it didn't give any noticeable change. 3. I didn't actually remove the throttle cable, I just popped the rest off and sprayed it out. I didn't trust myself to remove the cable and get it back on properly.
Post by grizzly on May 6, 2016 11:16:24 GMT -6
Hi all,
I cleaned out my carb with carb cleaner, and now my scooter won't go above 10mph. It speeds up fine on the stand, but when I'm sitting on it it doesn't get any real speed going. No bucking or kicking, it just speeds up to 10mph and cruises smoothly at that speed. Any ideas?
