Post by delta on May 24, 2016 4:40:07 GMT -6
how much amps voltage regulator output?? i will tray with car battery and tell.
for your information the scooter battery charge on battery charger, but its huge charge buts too much amps i used it to charge my car battery !!.
but i never take reading of the battery when i charge it with the battery charger. i will consider that
Post by delta on May 23, 2016 5:20:20 GMT -6
for your information i have dc lights and ac dci.
as i told you before when disconnect battery and scooter running i get 13.5 to 14.5 dcv in the red wire coming from the regulator, i connect it to positive wire without battery and start scooter with kick start there isn't head light even i revved the engine only dime tail light and dashboard light.
is the 13.5 dcv coming from the regulator not enough to power the dc head light even the small tail light ?!!!!
Post by delta on May 23, 2016 4:37:16 GMT -6
you mean ground wire to battery terminal ? i have light and ignition when turning ignition key while scooter not running, i think that mean my battery grounded
Post by delta on May 23, 2016 3:24:11 GMT -6
hi all, nice to be in this forum 150 cc gy6 scooter i have strange problem with charging system new stator new voltage regulator stator output is good and regulator output in red wire is 14 vdc when revving the engine.. that is good until i connect the red wire from the regulator to battery terminal no charge and when reading the voltage i read only battery voltage 12.4 vdc !!!! could any one please help me or tell me what the ...
