Post by jahno45 on Jul 6, 2016 9:01:19 GMT -6
Hey guys,
I installed a big bore 63mm cylinder to my SYM 150 and Ii gives the bike that extra torque it needed to pull hills and tow without killing my gas tank.
my problem is the bike will only start if I rotate the engine past top dead center and than hit the starter. I tried going from the 7amp battery to a 9amp battery with more cranking amps, but still got the same result.
Is there anything else I should be trying.
PS compression is now at 185psi
Thanks in advance David
