Post by foxico on Oct 16, 2016 17:48:35 GMT -6
By far the easiest way to find tdc is to remove the spark plug.Insert a screwdriver in spark plug hole and rotate the engine by hand until the screw driver protrudes from the hole the most,piston will then be at tdc,02works every time
