Post by lorenstump on Jan 15, 2017 18:03:29 GMT -6
35-135 way to rich, kinda expected that.
Post by lorenstump on Jan 15, 2017 15:53:15 GMT -6
No, I have a free flow filter and a customized Nibbi 27mm exhaust. Also PAIR system removed. Iridium plug, coil, adjustable DC CDI.
Post by lorenstump on Jan 14, 2017 23:47:20 GMT -6
Went out and checked the plug, pretty white. I actually had a 130 main and 35 pilot. Changed to 135 and 38. Bought one of those 10 main and 10 pilot sets from china for 11 bucks, free shipping.....lol. Did an A/F adjustment and advanced the CDI a couple degrees. Will see what happens with a short ride tomorrow.
Post by lorenstump on Jan 14, 2017 23:42:21 GMT -6
Ho Ho Ho!
Post by lorenstump on Jan 14, 2017 14:00:51 GMT -6
Justified buying it for my daughter... lol (it's mine). Since Nov. I've done tons of modifications. The cheap Chinese stuff makes it pretty painless and I love to wrench on things. Yeah for free shipping!
Post by lorenstump on Jan 14, 2017 13:48:55 GMT -6
Yep it's a 150cc. In order to pass CARB approval in California, the jetting was terribly restrictive. The pilot was 32 and main was unlabeled but probably 100-105. In the new carb I put 35- 120. This is just recently and am doing a plug chop today,
Post by lorenstump on Jan 13, 2017 22:29:36 GMT -6
I bought a new Znen in November. California CARB so that it could be registered here. Idle was hunting and the Air/Fuel screw was blanked off. Bought a 24mm for 20 bucks free delivery. Upjetted the main and the pilot jets. Switched the bowls as the stock had the drain valve and the aftermarket had a bowl screw. Made the proper adjustments. Night and day.
Post by lorenstump on Jan 13, 2017 14:35:04 GMT -6
No I haven't, seeems to be a vacuum pump set up on top and two other nipples on the side (perhaps coolant fittings). Seems the only other options are flat side 24, 28, 30 or a 30, 32 CVK. Think on a 150 a jetted 24 is probably fine, but some say different.
Post by lorenstump on Jan 12, 2017 21:28:04 GMT -6
There is also a Honda Elite carb at 27mm on Fleebay. 29 bucks and free shipping.
Post by lorenstump on Jan 12, 2017 15:01:23 GMT -6
Same thing here and I'm returning it. Just re-jet the 24.
