Post by axa on Apr 8, 2017 19:35:06 GMT -6
adding to this helpful info, I've confirmed you just need to pinch out the 12v switched wire, pop out the trigger wire and pop it in to where the 12v switched wire was and all is well.
I was going nuts never figured SYM would use some proprietary, seeming needless, CDI when any cheap AC CDI of eBay will suffice.
bonus. you can then use the left over key switched power line to hook up a regulated USB port as I did.
