Post by roadwolf on Jun 2, 2017 18:33:19 GMT -6
my gy6 had the same problem adjusted valves to .003 intake and .004 exhaust. She is purring and totally alive now. hope that helps.
Post by roadwolf on Jun 1, 2017 17:50:33 GMT -6
please let me know how that works out for you. If it is better I might just give it a try as well. Thanks again!
Post by roadwolf on Jun 1, 2017 16:20:44 GMT -6
hows it sound now? .004 in .003 out tried .004 on both and it was loud on tick not clanky but it was to loud. Is this to tight? it doesn't turn off turns right on. thanks again you all!
Post by roadwolf on Jun 1, 2017 11:27:21 GMT -6
Thanks ill try that can i turn it on with only two screws in the valve cover just to hear it sound for a couple secs and redo if i must? I imagine so guy. It would be a good idea to put the cover back on so u don't sling oil out. Put on bolt on bottom left and top right. just snug them up. I hope I am wrong but if that is not it a It may be a I hope I am wrong but that what it kind of sounds like the more you listen to it.
Post by roadwolf on Jun 1, 2017 4:44:05 GMT -6
Thanks ill try that can i turn it on with only two screws in the valve cover just to hear it sound for a couple secs and redo if i must? I imagine so guy. It would be a good idea to put the cover back on so u don't sling oil out. Put on bolt on bottom left and top right. just snug them up. I hope I am wrong but if that is not it a It may be a I hope I am wrong but that what it kind of sounds like the more you listen to it. i hope not it only has 1400 miles the sound only happened right after adjust before she would purrr but would have trouble staying on and i found that the adjustmeent was superrrr tight the rocker would not even move a little on tdc will post a video of sound after i adjust again
Post by roadwolf on May 31, 2017 18:23:40 GMT -6
Yes, I have tried .003 on intake and .005 on exhaust. I have tried .004 on intake and .005 on exhaust. I have found that .004 on both intake and exhaust work good for me on a gy6 150cc. Thanks ill try that can i turn it on with only two screws in the valve cover just to hear it sound for a couple secs and redo if i must?
Post by roadwolf on May 31, 2017 18:21:44 GMT -6
I might be afraid on running that like that on your 8 mile run at 50mph. I think you may be really taking a chance on that. It sounds pretty rough. Thanks im going to take my truck tomorrow and do the valvesright after work im not going to risk it. Thanks a bunch
Post by roadwolf on May 31, 2017 17:59:07 GMT -6
you set yours at .004 intake and .004 out?
Post by roadwolf on May 31, 2017 17:58:13 GMT -6
wow this is great thanks! Hope my bike can last til saturday :x
Post by roadwolf on May 31, 2017 17:56:06 GMT -6
its 4 miles a day 50mph
Post by roadwolf on May 31, 2017 17:48:45 GMT -6
think it was TDC the large O was in the center of the 2 valves and on the inside of the fan, the letter T was pointing towards a piece of metal inside the fan just like i saw in a youtube video on valve adjustment. So I hope I did it right on that front. I won't be able to work on the bike until saturday due to work. If I ride it like this until saturday will the bike be ok? thhanks!
Post by roadwolf on May 31, 2017 16:38:16 GMT -6
DOes this sound to loud to you all? i did both in and out at .005. This is my first time ever doing it should i redo it? Can I ride it like this until saturday?? thanks a lot all
