Post by mrbitz on Jun 19, 2017 21:47:39 GMT -6
yeah. I've removed and cleaned the carb three times now. It's fresh and clean gas. I tried pressurizing the tank with no success. It does also die at half throttle, it just takes longer to die. I'll try and take the carb off again. Any theories that don't include the carb.
Post by mrbitz on Jun 7, 2017 23:52:06 GMT -6
So...I've got an 85 or 86 (I don't remember and I can't find the title) Honda Aero 50. I've had it for several years and never had any serious issues. Now I pulled it out after the winter and it is acting up. So, here is what happens. It fires up and idles just fine. When I jump on the throttle it accelerates with out any hesitation for about 2-3 seconds. Then it suddenly sputters and tries to die. If I leave the throttle open it will die. However if I let of the throttle it will catch it self and general sputter back to an idle. If I let it idle for 5-10 seances I can jump on it again and get the same reaction. It does it when it is cold and when it is warmed up. Any ideas? I cleaned the carburetor, there is no restriction in the air inlet, there is clean gas, and gas in the bowl.
