delete
by: heread1979 - Dec 10, 2017 12:38:18 GMT -6
Post by heread1979 on Dec 10, 2017 12:38:18 GMT -6
delete
Post by heread1979 on Jul 29, 2017 13:07:19 GMT -6
I'll try getting the rocker arms, I believe it's 64mm for me.
I also think I have found another suspect to the cold-starting issue. The spark plug may not have been seated correctly. It looked worn out when I took it off, so I'm going to try replace that as well.
Post by heread1979 on Jul 27, 2017 10:35:21 GMT -6
Post by heread1979 on Jul 24, 2017 17:18:45 GMT -6
Post by heread1979 on Jul 21, 2017 16:44:18 GMT -6
Im gonna try to order a flexible magnet to see if I can get that screw out first, then get a new rocker assembly. I'll report back on the results
Post by heread1979 on Jul 20, 2017 15:01:51 GMT -6
what engine do you have? it's probably on the side with the transmission cover, should be stamped in "157QMJ"
Post by heread1979 on Jul 19, 2017 19:51:23 GMT -6
try getting a flexible magnet and open drain plug slide it around till it latches good luck. do you have a link for such a thing on amazon? And would it work if there is oil?
Post by heread1979 on Jul 19, 2017 19:50:42 GMT -6
some times it can be more economically feasible to replace the engine than to repair one. I don't even know how to replace the engine out of the scooter . I'd rather try to get the screw out first and doing the repairs i intended before thinking about it. Otherwise it'll just be better buying another scooter
Post by heread1979 on Jul 18, 2017 18:05:07 GMT -6
Hey guys, I am new to these forums and scooter repair, so please bear with me. This whole thing began when my scooter was having issues trying to cold start. But when I start it again while the engine is warm then it starts right up. So I suspected that some possible solutions were: cleaning the carburetor, replacing the choke, and adjusting the valves. I took off the underseat storage and did some visual inspections. One of the first things I saw was the air intake tube was cracking and breaking apart. Maybe that was causing the scooter not to start? So now I gotta replace that intake tube. And the carburetor is located right under it so I had to take it off regardless. The first thing I decided to do was to do the valve adjustment. I watched many Youtube videos on how to do this and I thought I was well prepared. I took off the engine head as instructed, removed the 4 bolts. After that, things did not go as I planned, it actually has caused me more problems to deal with! First of , after using the feeler gauge, I was tightening down the bolts on the valves , but the inner screw just would not stay put when I held them with the pliers. And then I found out that screw has been stripped , in other words it won't screw to the hexagon nut. The second problem was that I was being so clumsy (I was working outside in the summer heat) that I've accidentally dropped a screw into the camshaft hole. So I've had to try disassemble the rest of the engine head, ended up removing more screws and bolts , since there were so many tight spots my wrench wouldn't fit unless I removed part of the plastic frame. This whole process took me a few days to get through. I've already removed the camshaft off of the chain , removed the muffler bolts that were attached at the bottom, removed the manifold, along with many other screws, then I was able to take off the head. But now I've reached to a point where I'm suck. There was another hole I found what seems to be the inside of the oil compartment, the screw must have fell in there. Well f**k! I've done all that removing engine head for nothing. So I drained the oil out from the engine , and now I just need to figure out how to get inside the oil compartment to get that screw out. This whole thing has become a hassle now, what I thought was going to be simple and easy turned out to be a nightmare. At least from all this I've gotten the opportunity to learn more about my scooter. Hopefully somebody can help me with this what else I need to do. Preferably someone who's had a lot of experience and knowledge with Chinese scooters / GY6 engines. In the end I hope I can revive my old scooter, do a few modifications, and make it like new again, even better! If anyone needs pictures or anything , please let me know. And if anyone wants to know what kind of scooter I have, here's a link with all the specs: www.df-motor.com/product_show.asp?id=683
