Post by smallengineguy on Sept 21, 2017 20:04:05 GMT -6
as soon as I get the front plastic buttoned up I will have to go for a test run
Post by smallengineguy on Sept 20, 2017 21:27:57 GMT -6
OK now found the problem rocker high/low switch is bad but I got one side to work but will order a new switch.
Post by smallengineguy on Sept 14, 2017 11:57:42 GMT -6
well so far I have replaced the cdi box,ignition coil,ignition switch and all the locks,a new drive belt as well as cleaned and lubed the front clutch put on a new carb and it runs good,now waiting on a new voltage regulator then I can move on to the back tire reassemble it and ride!
Post by smallengineguy on Sept 12, 2017 21:13:42 GMT -6
good job,sweet little ride!!
Post by smallengineguy on Sept 12, 2017 10:19:47 GMT -6
voltage regulator checks as bad so I think that is the problem,will order a new one and see.
Post by smallengineguy on Sept 12, 2017 7:23:51 GMT -6
checked the battery wires as well as talked to the guy who gave it to me he said the headlights worked when he parked it but it sat for 3 to 4 years also?
Post by smallengineguy on Sept 11, 2017 14:33:46 GMT -6
Hello fellow scooter riders,i am new to this site and I have a longbow 150cc I am having a issue with headlights and running lights on my scooter the alternator is working but there is no voltage getting to the high/low beam rocker switch.any help would be great.
