Post by vstrom on Oct 6, 2017 16:38:25 GMT -6
Did you straighten this out?picked up an axon 50 with 45 miles on it. It appears this is a DC fired scooter. It came with an 8 coil stator which I replaced due to a no spark condition and now I have normal ac voltage with the regulator unplugged 20 volt AC - 50 volt AC while revving. When I plug regulator back in drops my ac voltage down to 7 or 10 volts ac and I have a no charge condition at the battery. It came stock with a 4-pin pigtail regulator with one extra bullet connector wire that I believe feeds the enricher on the carb. I found one place that sold this regulator online but one still same condition even made a pigtail to run a standard 4pin. And have same scenario why can't I convert this AC voltage to charging voltage for the battery? Grounds ohm out good direct feed to battery is good. This is a strange bike looks like qlink used the charging system from another style of bike. Is the 8 coil stator that I put in wrong?
