Post by speeddog on Mar 11, 2018 15:55:52 GMT -6
I have been having problems starting my scooter sometimes recently and was hoping to get a second opinion before dropping the money to replace my CDI and coil since I would want to upgrade if I am already replacing it. The scooter is a cheap Shenke 150 (nearly identical to a Jonway from what I have gathered) that I got for free. Some days it will start, and some days it won't. When it doesn't start, neither the electrical or kick start will get it going. When it does start, it will sometimes cut out while I am riding it. The drop in power is immediate, not sputtering, which leads me to believe it is the electrical system. When the scooter does die, it usually will not start again immediately, and tends to be more likely to start the longer I let it sit without trying. I started by checking the fuel line, just to be sure it was getting gas, and it was. Next, I replaced the spark plug from the stock plug to a NGK plug just to make sure that wasn't the problem. I have also checked the voltages out of the stator, and it seems to be functioning properly. I also tried disconnecting the killswitch from the CDI to ensure that was not causing my problem. I was just curious if a bad CDI is likely to cause these intermittent issues, or if it probably points to another problem, and if so, what. Thanks in advance.
Post by speeddog on Mar 11, 2018 12:20:35 GMT -6
I need to slow down for sure. I really mixed a lot of stuff together. Back to the facts: I was on a short ride - and the sound definitely is not the same as before. The sound from the muffler is not the same, it is more popping instead of humming (Sorry really don't know how to describe it in english ![:D](//storage.proboards.com/3059616/images/j7oliHrgM6d9allIZs7k.gif) ). But I noticed the different sound mostly in the first few minutes only. There's no misfiring or anything, the engine runs nicely, but has no power. I took some photos and will upload them probably tomorrow. Anyway, I detached the whole engine from the scooter as I decided I should change some things (head gasket and seals). And put a C clip instead of a G clip on the piston. So I guess I will start from the bottom anyway. Hey bro unless there is some immediate need to take the piston off the rod Don't Touch that Clip Please until you report with a picture. Just leave it alone for the now.
