Post by lc on Jan 26, 2020 12:58:09 GMT -6
Still at same place, no break lights therefore no start. Cannot determine where or how to get break lights. Is there any other fuse other that the fuse box, the inline from the battery, and there is one leading to the sound system what ever that is.
Post by lc on Dec 29, 2019 9:38:59 GMT -6
No power to start switch. It appears that a power source is missing somewhere. The fuse block end (forth) with the red yellow leads do not have power, and i am sure at this point the power source does not come from the ignition switch (black wire). If i knew where this power source originated i may be able to track this issue down Thanks for your help!
Post by lc on Dec 29, 2019 8:00:42 GMT -6
Thanks, I will give that a try..
Post by lc on Dec 26, 2019 8:00:58 GMT -6
Still at the same place...no break lights, no start with new starter switch. Turn lights, horn, security...ok
Post by lc on Dec 15, 2019 9:30:41 GMT -6
Thanks again!
Post by lc on Dec 13, 2019 10:35:17 GMT -6
Couple of notes concerning my issues with the yy250t scooter. I have replaced most of the switches including the starter switch, and aslo the rectifier. I just replaced the relay, and as mentioned replaced the security/start module has been replaced. I also have replaced the right handle bar stop switch. Now, if i remember, the headlights should go on after the scooter starts, but the headlights and the taillight go on with the ignition turned on. Is that a problem? Still, the stop lights do not work, and there is no power to the right handle bar stop switch, and pressing to starter button does nothing. Thanks! Additional help will be appreciated.
Post by lc on Dec 12, 2019 15:42:29 GMT -6
Yes, jumping the solenoid will turn the stater motor. I appreciate your help and thanks. Hope you will continue. I knew nothing about these scooters. Learning a little as we go....ha.
Post by lc on Dec 10, 2019 16:15:23 GMT -6
I bridged a wire between the last fuse the was dead, and the adjacent fuse holder. The headlights and taillights came on, but no break lights and the engine does not turn over. What would be the next thing to do other than trashing the whole scooter....
Post by lc on Dec 10, 2019 15:20:43 GMT -6
I have looked very closely to the fuse box (fuse holder) and do not see any issues. Is this worth replacing the 4 blade fuse holder? Thanks so much as i cannot get this tt250t to respond.
Post by lc on Dec 8, 2019 23:06:38 GMT -6
I have a yy250t that is dead except the horn, front turn signals and passing lights from the dimmer switch. There is 12 volts to the ignition switch, and the fuse box get 12 volts to three of the 4 blades. Question, should all of the fuse blade holders have 12 volts with the ignition on? If so, could i have a bad fuse holder? ( have replaced the ignition switch and the security unit...by the way, there is power to the security unit ). Tail lights do not come on at all. Help will be appreciated. Thanks.
