Post by scooterj on Apr 10, 2020 20:04:49 GMT -6
OK, so I pulled the starter on my scooter it was screeching from lack of lube on my (ZNEN 250) lubed it up put it back in the hole and now it just spins freely ?? Did I miss something ?? it turned over fine before except it made a screeching noise .. now it spins and wont turn the engine over.. ideas? I took it apart and found the gear inside the case was intact and I assume where it's supposed to be but after days of frustration, I gave up and sold it.. there is just not enough information available in a timely manner to make it worth messing with ..
Post by scooterj on Apr 8, 2020 17:04:04 GMT -6
Hi, I recently took a 2008 ZNEN 250T-B scooter /motorcycle in trade that has been stored for about 2 years , I took it apart when I found the starter was not turning the engine over quickly enough to start, I checked spark (weak) but a new plug fixed the spark issue , but the starter itself is making death noises lack of lube I am assuming .. when it did turn over compression was good (over 100 psi) it also has a bad starter switch or possibly solenoid, and I noticed the front brake has no pressure to the caliper even though the fluid is full , my question is where does one get parts for these units ?? I don't believe there are any dealers near by my location and amazon is hit and miss at best , also how do I determine which engine this has ? oh I'm a trained mechanic just the Chinese market is not my strong point lol..
Thanks in advance J.
Note , I couldn't get it to work and there's not enough information out there to make it worth my time, but I did find out their is a large market for these locally and did not have any problem selling it !
