Post by dan2001 on Oct 2, 2021 19:58:07 GMT -6
So my wife picked up this 2007 lambretta uno150cc scooter from a guy that said “ I was running 3 weeks ago and now it won’t start”. So we get it home and I check for spark and fuel and it’s all good. Then I noticed oil coming from the exhaust. I figured it was a bad head gasket then I pulled the muffler and I noticed oil there too. But it won’t start so I watch a couple videos on taking the head off and making sure timing was correct. And I noticed that the piston had valve marks like the piston had made contact with the back of valve body. So I pull the cylinder and the piston falls off of the connecting rod. The cylinder had a bug scratch down the side. So I’m thinking I need to order a master rebuild kit. So I start searching and I run the vin and it just says it’s made by adly but it doesn’t give me a model number so I’m not sure what it is to search the rebuild kit I need. All I known is that it’s a 4valve and all the rebuild kits I find are for 2 valve. So I signed up on this forum hoping that someone can help me out.
